Clutch problems - FirebirdV6.com/CamaroV6.com Message Board
Clutch problems
  • Clutch problems
    Driving around my clutch will randomly stick in and i have to pull it out it happens only when i am in gear. I say it happens 2 out of 10 times i use my clutch. Also last night I pulled into a parking lot and stopped and was gonna put my car in neutral and it wouldnt come out of first and the clutch was all the way to the floor I had to let is stall then pull the clutch out and then it went into gear just fine??
    Whats the problem? :(
    <a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
    Any one?
      sounds like you're probably low on clutch fluid and introduced air to the slave cylinder. OR......you have a worn out throwout bearing. More than likely, if you've done a clutch replacement recently, or haven't checked the fluid level in a while you have air in the clutch system. Just bleed it and drive around. If it still sticks......throwout bearing is bad.
      Nitrous is like a hot chick with an STD....you wanna hit it, but you\'re affraid of the consequences...<br /><br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=244935\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=244935</a>
