i am gettin a "popping noise" from the front end when i steer the car while applying the break? could it be struts maybe, has anyone had this problem or would they know what it could be?
hey thanks a lot for the tips. is this something i can fix at home then? cuz im really not too sure what to look for...i guess ill just have to take it to the shop???? the car has 162000 miles on it, and its pretty much all original. except for all new pads and rotors, alternator, and i just did a lower intake manifold, valve cover, and upper plennum gasket job on it. hopefully its just something that needs a little tightening
I have an old FWD car that has a broken sway bar linkage that I need to fix. It rusted apart. You can hear it banging when I go around corners, bumps, braking. I assume Firebirds have swaybar linkages too up front, but I have not paid attention when I'm under there.... something else to check, and an easy fix. Just look around under there, you may find something rusty/loose.
The following is easier if you have a friend, if not, I'm sorry, but continue anyway.
First, firmly bounce the nose of the car up and down, and listen for noises. If you hear the pop, or any similar noises, then torque all the strut mount bolts (upper & lower) to their proper specs.
If you hear no noises from the above, then turn your key forward one click to "ign". Do not start the car. Turn the wheel left/right and listen for noises. If you hear the bastard noise, then you have problems in the tie-rods or similar. (you can also do a "secondary" steering test with the car running)
If you don't hear anything again, then you will have to inspect the entire front suspension from below. If anything isn't up to specs, tighten it. If anything looks flimsy/broke, then replace it.
Once you've gone over everything, and possibly fixed the problem(s) (or so you think, you silly boy), it's time for a lube job.
Lubricate all the grease joints. Make sure not to overgrease, as this will cause damage. Damage makes that accursed noise happy, and you don't want that, now do you?
After all this, if you haven't found the problem, then it might be a clunk in the brakes. Or, possibly something more sneaky.
The only thing on the front suspension that's a pain to do at home, is too replace the springs. The rest can be done with simple or specialty tools.
[ September 29, 2005, 10:34 PM: Message edited by: Rabid Dog ]
