?'s about Pulleys - FirebirdV6.com/CamaroV6.com Message Board
?'s about Pulleys
  • ?'s about Pulleys
    Anyone having any issues with cooling or charging while using pulleys?
    Also, I read somewhere that running an electric waterpump would be better than using the pulleys alone, any truth to this?
    Thanks
    1999 Firebird
    I noticed that my power windows are so slow to open and close with the pulleys
      i guess an electric would be best, to take the hindrance away from the mechanical crankrod.
      but electric it has to convert from mechan to electric to mechan i think
      i thought underdrive pulleys were to free up mechanical drag will maintaining electrical power.?
        probably just your motors going out. common problem with our cars
        http://www.bowtiev6.com/
          Originally posted by 97rs4life:
          </font><blockquote>quote:</font><hr />Originally posted by BiH:
          probably just your motors going out. common problem with our cars </font>[/QUOTE]Exactly. But the pulleys can cause a voltage drop too. I'd say that the motors are going, and the timing was just uncanny. Or, the drop is accelerating the problem. (Our w/m's die or slow from lack of voltage to the motor)
          If you see them start to "skip" or work intermittantly, it's time to yank them and remove the safety strip. (If you don't have children or pets that ride with you)
          <b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
            no this just happened when I installed the pulleys,because when the car is idling the voltage sure drops down
              The voltage should drop down if you are using underdrive for the alternator. Underdrive uses less force so it frees up the motor, I haven't ever heard of it dropping that low that it wants to kill the car.
              FTRA kit, Whisper Lid, free ram air mod, Richmond 3.73 gears, Dynomax Catback, Poly Tranny mount, Vette Wheels, Expensive Audio equipment :). HID headlight Kit, Billet Grille, Billet Antenna, Eurotails, Carsound Cat
                it doesnt kill the car when its low,its just all the lights at night that get low when the car is idling
