3.4 Code 36 - FirebirdV6.com/CamaroV6.com Message Board
3.4 Code 36
  • 3.4 Code 36
    Alright, I've not been able to find out much at all about this and my patience is running out. I finally eliminated my cold start idle control problems by replacing the MAP sensor, which was faulty (code was stored on the computer). Not long after, the very same symptoms, aka horribly sporadic idle ONLY when the clutch is pushed in, started showing up when the engine is warm.
    The MAP sensor code is gone, but now I have code 36, 24x signal circuit error : faulty circuit error from coil packs to (ignition) module. I have replaced both the 24x crank sensor and the camshaft position sensor very recently. I have also had the ignition module tested at the local Autozone (it passed repeatedly). There is nothing else in the 24x circuit!!!!!!
    How do I fix this? I'm pretty sure that I'm getting spark consisitently but the engine is setting the timing wrong. PLEASE give me some answers on this before I lose my mind.
