output shaft seal? - FirebirdV6.com/CamaroV6.com Message Board
output shaft seal?
  • output shaft seal?
    The output shaft seal or rear tranny seal (whatever its called) appears to be leaking a little. How much does it usually cost to have these replaced. Thanks
    1995 3.4L M5 Camaro<br />Bullet Performance Exhaust, K&N FIPK, Stage 1 clutch, Short shifter, Hotchkis STB, Taylor Ignition wires, NGK spark plugs
    call your local dealer or shop ;)
    2000 3.8 A4 Pewter Camaro
      the seal itself is like 3 dollars, if the mechanic doesnt drag a** doing the job, it should take no mare than a half hour, i just did one my self in my 86 firebird 2.8 m5.
      --1986 Firebird M5-- TEAM RED
      http://www.cardomain.com/ride/2109812
        so should I be expecting no more than $50 to get this replaced? I just want to get an estimated figure so the shop doesnt try to rip me off.
          Had to replace mine last summer. Spend like $3 bucks from GM for the seal. Local tranny shop swapped it out for $35 bucks. Only took them like 20 minutes. No problems since.
          1995 Camaro 3.4L A4<br />Check out my other ride. <a href=\"http://www.sounddomain.com/ride/820732\" target=\"_blank\">www.sounddomain.com/ride/820732</a>
            Mines doing the same thing too and I'm about to replace it myself. Is there like a special tool I need to use to take the old one out?
            1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
              A flat-head screwdriver and a mallot. It's a very simple install.
