I went to my car to listen to some tunes for lunch right. Well I put it the key open the switch to lower my windows and they start going down slower than usual. Then I turn on my stereo and the lights to the stereo where dimmed, so I was like WTF. Could it be my battery or alternator.
I would check the battery first since if you turned on the accesorys and had low power. But Also check and see if your "check guages" light is on because that would most likely be an Alternator. Advance Auto can check you electrical system for you and tell you what the problem is.
JR
1996 Camaro 3.8<br />Edelbrock Exhaust, SLP Intake, Bosch, Platinum +4 Plugs, Accel Wires, SLP fan switch<p>\"Let the good times roll\"
could you even start your car after that? Your battery is dead, but it could be dead due to the alternator being shot. The only way to know for sure is to test the alternator as you already know the battery is dead.
If it will start every time, it's probably not the battery. Once you start it, does every thing go fine, gauges read normal? If you can get it started, take it to Advance Auto for a free check of battery and alternator, they don't even need it off your car. Sometimes a bad starter can kill a battery too.
I'd check the starter and the alternator. If you get a higher output alternator, that usually fixes any dim lights or low sound levels out of your speakers.
Starts every time, however at start up, the lights are a bit dim, then if I give it a little gas it seems to get current flowing and then the lights are back to normal and stay that way. I guess I just have to get them checked.
3 days ago
