Removing Radiator Fans - FirebirdV6.com/CamaroV6.com Message Board
  • Removing Radiator Fans
    I am trying to remove the crank pulley and I need more room for my impact to get on that nut. How do I remove the Radiator Fan Assembly on a 98? I can't find any bolts and I don't want to start pulling on it and break something. It looks like there are 2 radiators also? Sorry if these are dumb questions I just don't want to mess up anything.
    Thanks,
    Devin
    \"a civic is like a tampon...every pussy has one\"
    There should be some bolts that bolt the platic radiator shroud to the metal frame. So basically just start taking things apart and you'll get them off. It looks like two radiators, one is the radiator the other is the A/C condenser.
    g
    2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
      First remove the air intake stuff above it. Then on mine the fan assembly just sat in there. No bolts or anything.
      Matt
      1998 Mystic Teal Camaro M5
