Overheated! *Fixed* - FirebirdV6.com/CamaroV6.com Message Board
Overheated! *Fixed*
  • Overheated! *Fixed*
    I was driving around for 3 hours to see if someone would install my Bullet in place of the Cat, and I got stuck in a traffic jam from 419 to 17-92, and all the way down 436. When I got home I lifted the hood and coolant was flowing out of the reservoir, and all over the ground. I can't understand why my car can't sit in traffic for more than 20 minutes without getting to hot. Every time I drive my car for more than 20 minutes I can hear coolant bubbling inside the radiator hoses, but this time it decided to shoot out of the reservoir. I think I should get a coolant flush, and check to see if my fans are working. How can I tell if the fans are working? I have never heard any fan sounds since I got the car. Stupid a** Florida drivers! [img]graemlins/rant.gif[/img]
    [ October 07, 2005, 02:17 PM: Message edited by: L36Camaro ]
    2002 Z28 A4
    SLP Lid | TSP Rumbler | P&P Throttle Body | No Cats | 3.42s | M/T Drag Radials | No Front Sway Bar
    12.76 @ 108.42 w/ 1.90 60’
    you coulda called around
    i hear coolant bubbling in my radiator and the hoses all the time
    have you Ever flushed your radiator/coolant?
      if its cool when driving and hot in traffic sounds like something with the fans for sure.
      with car on, turn on AC and pop hood and see if fans kick in.
        Originally posted by ezrollin:
        you coulda called around?
        I called a million places and they all said no, then I went up to Super Street a local performance shop and he referred me to 3 muffler shops, and all 3 muffler shops said no, then on the way home in the traffic jam I went to 4 other places which all said no. D*** Florida!!!
        No I have never done a coolant flush since I got the car in February.
        2002 Z28 A4
          Should I go try that now, or wait a couple hours?
          2002 Z28 A4
            BTW, I'm in trouble because when I got home I punched a hole in the garage door. Oops :mad:
            2002 Z28 A4
              I have heard this place will do it
              superior muffler on goldenrod and valencia college
              from a local board, I was going to try there once my clutch problems were fixed.
              Probably won't have much luck calling anyone even this shop. Its illegal to pull the cats on a car. We can get away with it in FL because we don't have inspections. You hvae to find a sort of "shady" shop to do it.
                I guess let your car cool a little. If its overheating but try it later.
                I think they will turn on even if you just go out, turn the key(not turn car on) and turn the AC on.
                  so if you have no AC, the AC switch is like a free radiator fan switch LOL
                  i love it, ghetto is how we do
                    I turned the key to the on position but did not start it and put on the AC, the radiator fans did not do anything, I also moved the AC fan button to max but nothing happened. Do I have to completely turn on the car for the radiator fans to work or are they broken?
                    2002 Z28 A4
                      Try it once with the car on, can't hurt anything really. (atleast it shouldn't lol)
                      Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
                        [img]graemlins/rofl.gif[/img] Alright, I'll go try it right now.
                        2002 Z28 A4
                          I turned on the car w/ the AC on and reached behind the radiator and felt air blowing on my hand, does that mean there working? BTW, I stuck my finger in a little to far because it is dark outside and the fan cut my finger a little bit. I'm a dumb***! :rolleyes:
                          2002 Z28 A4
                            good news is your fan motor isn't broken
                              I just checked it again w/ a flashlight, and I saw both fans working great! Could they not be turning on when the AC is not on, or do I need to flush & burp the cooling system? Oh, one more thing this is the first time I ever turned on the AC in my car, and boy does it feel a million times cooler than my Mom's '89 Mercury!
                              2002 Z28 A4
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
