Low RPM miss - FirebirdV6.com/CamaroV6.com Message Board
Low RPM miss
  • Low RPM miss
    Ok so I put new a new torque arm bushing on today, then a new transmission mount. I thought they were just rough at first, but then I realized my car is having hesitation and it is only up to 3000 RPMS. It is missing for up to this point and then it stops. Doesnt this usually happen the other way around? Miss at high RPMS intead of low. What could be causing this. It all started when I let my car down off the lift today and nothing under the hood was touched, just a new torque arm bushing and a new transmission mount. Also, I seem to be running at 210 now instead of 185 or whatever it normally is.
    And no PCM codes whatsoever have been set so far.
    Any suggestions would help. Wires are new and plugs are as well. Well 5,000 miles new.
    Thanks
    Jared W. Drummond<br />jdrummon@vt.edu<br />1997 3.8 Firebird M5<br />-----------------------------------<br />*Flowmaster 80 Series Muffler* *SLP Cold Air Intake* *Zexel-Torsen LSD* *1-Piece DS* *Eibach Pro-Kit* *Removed MAF Screen* *Manual Fan Switch* *Mobil 1 Oils*<br />-----------------------------------<br />*Pioneer Premier DEH-920R Headunit* *Orion Cobalt 6 1/2\'s* *Sub Stealth Box w/ Alpine SWR-1021D* *Kenwood 728S Amp for Sub*
