help quick. Missing a fuse? - FirebirdV6.com/CamaroV6.com Message Board
  • help quick. Missing a fuse?
    I was looking at the fuses under the hood and the little 20 amp fuse for the air pump is missing. Am i suppose to have a fuse there? And If I am would this have done any damage?
    1995 3.4L M5 Camaro<br />Bullet Performance Exhaust, K&N FIPK, Stage 1 clutch, Short shifter, Hotchkis STB, Taylor Ignition wires, NGK spark plugs
    I don't think it would do any damage, I think it is more for emissions then anything else. If it has metal clips in there to put a fuse in, there should be one in there. If it is just a plastic square, it is a blank and not used. (no metal prongs to hold a fuse)
    Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
      ya the metal prongs were there so I put a new fuse in Thanks
