when do u usally change pvc val? thanks
pvc val
pvc val
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
You mean PCV Valve? Don't really need to change it too often. Maybe 30-50K, and even then chances are it'll be fine. But it's such a cheap and easy thing that it's not gonna hurt to just change it.Matt
1998 Mystic Teal Camaro M5
opps my bad pcv valve ok cool cuse my car 91k on it so i guess its time to change it will i feel anything diffrent if i change this?2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
ok2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
not a fool proof way to check it, so if you take it out just replace it. It is less then 3 bucks.
Also, if it bad you may notice more mid range power. I did and so have some others.97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
ok cool thanks guys2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
save the o ring
cool changed it and yes i save the rubber o ring thanks for the help2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
