Whats the best type of coolant to use???? Whats the best thermo to use as well for a 94 Firebird as well.
Bad coolant...
In LA? I'd go with a 160* thermo, and green coolant. The red stuff (dex-cool) is absoultely HORRIBLE.
example: http://www.geocities.com/b_gillie/dexcool_problems.html
I thought it was because I used regular tapwater, but then I used distilled, and it did the same thing. The fluid turned brown in color, with a jello-type consistancy. I just changed to green yesturday too...thank god!sigpic
Cause generally if you live farther up north, it is reccomended to get a higher thermostat, so the heater will work better, and your engine will stay in the operating temperature. I have a 160*, but I live in texas. Also, I am having the same problem with dexcool, I just flushed and filled like 6 times in a row, 2 days, ago, and the very next day (yesterday) sure enhough, brown sludge all up in the radiator around the cap, I will do this again, and switch to regular coolant. Im glad I payed like $11 for dexcool. :rolleyes:Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
