I just had half of my gauge lights go out on me. Now at night, I can't see my speed, voltage or fuel gauges.
How hard are these bulbs to change? Is this gonna involve removing the dashboard?
1997 Camaro,<br />SLP cold-air, Hooker Supercompetition catback, Air temp. module, Powerstat thermo, 1LE Aluminum drive shaft, 3.42 POSI rear, 1LE sway bars front & rear, Powerstop crossdrilled rotors on all corners, Torque Thrust II\'s (17x9.5 front & 17x11 rear), and a couple other goodies. <a href=\"http://www.villagephotos.com/pubbrowse.asp?selected=84487\" target=\"_blank\">http://www.villagephotos.com/pubbrowse.asp?selected=84487</a>
yes. but its not hard. just remove the two screws uncer the bezil cover. pull that out and than remove the 4 screws holding the gauge cluster in and pill it out. its easer if you put the steering collum all the way down. hop this helps a bit. the bulbs size is 194.
1999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
