150 MPH Conversion - FirebirdV6.com/CamaroV6.com Message Board
150 MPH Conversion
  • 150 MPH Conversion
    Has anyone done this? If so, how'd you recalibrate the speedometer to give an accurate speed?
    \'00 Camaro | V6 | A4 | White | Y87 | Neutral Leather | Monsoon | Flowmaster | Raised Air Box | Clear Corners | K&N Air and Oil | Mobil 1<br />160* T-Stat on the way
    a mechanic at lou grubb chevy told me that what controls the speedometer to make this kind of conversion work is in the computer, i wanted to do this myself . :mad:
    Xnenon headlight conversion<br />k&n cold air induction<br />85 shot of nitrous (NOS)<br />255 lph walbro fuel pump<br />80 series flowmaster<br />z rated 255/50\'s<br />misc. auto meter tach and a-pillar
      Time to call my dads friend, thanks for the info. [img]smile.gif[/img]
        can i put the gauge cluster from a trans am with the 150mph speedo on my car? Will everything bolt up and plug in? I know i'd have to re-calibrate some stuff but is the install and the connections easy to do? thanks
        Logan
        16.8 1/4m at 2700ft elev.(b4 driveshaft and headers)<p>1995 M5 Firebird 3.4L sittin on Pirelli P4000\'s<br />mods: cheesy ebay intake<br /> 2.5\" cat back Gibson exhaust w/ 3\" chrome tips (Now a SPINTECH exhaust)<br /> MSD DIS-4<br /> Taylor Spark Plug Wires<br /> ASP Crank Pulley<br /> Alum. Drive Shaft<br /> Pacesetter Headers<br /> Nitrous Works Wet Kit(75shot)<br />Next Steps: <br /> Stuff for bigger nitrous shot!!!!!!!
          as far as i know yes, but your speedometer is going to say your going 75 when you realy only doing about 40, up to you.
              97+ cars with the digital odometer are VERY easy to change out. You just take one out and put the other in. EVERYTHING will work, that is all gauges, tach, speedometer, etc. except for the odometer. The odometer will give the mileage of the car u got the gauges from. Everyone with the older mechanical gauges will need to switch out resistors in the tach, i really don't know about the older cars, but i know about 97+ from experience. The only catch is if u have a 2001 u have to get 155mph gauges from a 2001 z28, cuz they change the wiring up in the gauges year to year for some odd reason. I know this from experience also since i fried a set of 97 gauges in my 2001, sent them back and got 2001 gauges and they work perfect. You may need to get the Air Bag sensor in the gauges itself to resyncronize with the Air Bag sensor currently in your car, I had to do that also, but any dealer should do that free of charge. Only drawback, again, is u will have the mileage from the "donor" car.
                so everything should work if its the same year as your car right?? what about for the 2002's, because you said only 2001 or is it 2001 & 2002's? has anyone else done this and had similar or different results...
                merlin
                2002 Firebird<br />2003 Yamaha YZF 600R
                  I just want a new white guage overlay. Not the whole assembly. Thanks for all the info though.
                    you can get white face guage over lay for the 115-120 scale that on our cars. Look in my sig.
                    Thsi is where i got them:
                    http://members.aol.com/rmacewen1/index.html
                    if that doesnt not work just try www.macewen.com
                    or www.macewenmotorsports.com
                    Mike<br /><a href=\"http://www.my99firebird.gq.nu\" target=\"_blank\">www.my99firebird.gq.nu</a>
                      I put a 95 Z-28 guage set in a 95 3.4L and it worked fine. it's computer controlled and a direct replacement
                      94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
                        <blockquote>quote:</font><hr>Originally posted by stagen:
                        I put a 95 Z-28 guage set in a 95 3.4L and it worked fine. it's computer controlled and a direct replacement<hr></blockquote>
                        What about your odometer?
                        I have a 2001 Firebird, and am seriously considering getting the gauge cluster from a 2001 trans am to put in.
                        Will the tach and speedometer work correctly, then???
                        Also, is there a way to fix the odometer? Im sure if a dealership has to replace a gauge cluster under warranty, there must be a way to change the odometer reading since its a replacement.
                        Property of Dave Hamburger
                          it should its all computer controlled
                            stagen,
                            Wasn't your tach off since it's expecting 8 signals but only sees 6? I've had a 150mph cluster sitting in my closet for nearly two years waiting to find a solution to that problem. I know all the gagues should work right except I thought the tach would be off. Do you know if this is the case or not?
                            Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
                            • Andy H
                              Transmission removal help!!
                              by Andy H
                            • 2.8 Bird
                              Abs inop
                              by 2.8 Bird
                            • fishin
                              by fishin
