40-48 fuel psi but still surges - FirebirdV6.com/CamaroV6.com Message Board
  • 40-48 fuel psi but still surges
    just check my fuel pressure and it does not go any lower then 40 psi. Now to get rid of the surging should i replace the coils and wires.
    PS. the old owner has bosch plugs in it, should they go.
    Surge like how? When I would let off the gas on my A4 to coast, it would surge when I had the MAF screen removed.
    If your MAF screen is removed, put it back in.
    But I'm assuming you have a surge or miss all the time.
    -1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
      yes it misses a little when I floor it. The maf screen is still there. the surge will be when I get to any speed and stay there, like 30 mph and the rpms are around 2000 it engine will drop to 1700, then when you hit the gas a little its like the engine is choking, you cant get up to speed with out droping a gear down . It is a auto tranny
        I had a comparable issue quite a while back. I ended up doing everything except having the tranny checked out. Unfortunately it was the a4 valve body issue and i neglected it so long I had to have my tranny rebuilt. My car didn't even throw a code until 8-10 months down the road, it was a very slow degradation. If you have issues with surging as soon as the tranny upshifts and you hold the throttle steady you might have the same issue as I did. Good Luck
        2000 Bright Red Firebird<br />GU6: 3.42 rear end<br />WS6 hood/airbox<br />2.75\" back w/ WS6 muffler and HI-Flow Cat
          are the bosch's the stock ones? You might just try some lucas fuel cleaner, change fuel filter, change plugs and wires before doing coils and whatnot.
          97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
            I had the sonnax kit istalled about a week ago and Dacco trans said the tranny is going/shavings of metal in the pan.
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
