pulley screw up/strip - FirebirdV6.com/CamaroV6.com Message Board
  • pulley screw up/strip
    ok, so i had a bad idler pully. I get it in my head that it is reverse thread and when i buy the pulley i ask the guy and he says yeah they are both reverse thread.
    Well i get home and get a long wrench and the liquid wrench and long story short i partially stripped out the female threaded part. Not the bolt, but the part it screws in to will thread in partially hand tight, but not any more than that.
    Question is, can i just replace the small piece the pully bolts to or do i need to get a whole new ac pully part as well.
    Thanks for any help everyone.
    97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
    I need to get the new part but was hoping someone new this before i buy stuff i dont need. Only car so i cant take it off then figure it out.
      anyone?
        Hey Red, I'm thinking all of our 3.8's are basically identical so Im going to take a shot recommending you buy the entire pulley assembly part thats bolted into, this way you have a brand new part and 2 pieces from it to disassemble with. Otherwise a trip to the local pick n' pull will probably help you too. I noticed that reverse thread scheme myself and almost did the same thing as you did while replacing my serpentine belt.
        Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
          its not the tensioner assembly that you push down to take off the belt. It is the other pulley on the lower left under coolant hoses and in front of ac.
          If that is an assembly, do i just ask car part stores or salvage yards for an idler pully assembly. Ifso it looks fairly easy to remove/instal, anyone know if this is the case.
          Brad
