Serpentine belt replacement need sugestions - FirebirdV6.com/CamaroV6.com Message Board
  • Serpentine belt replacement need sugestions
    Got a 97 Camaro 3.8 with a/c. Anyone got part numbers of the gm belt or some other one ? I searched but saw mixed results with the gatorback. How is the good old ac delco belt ? Thanx. Oh and also is this a hard process ?
    1997 Camaro LS1 RS
    1994 Camaro - Sold
    1999 Trans am Vert - Sold
    A Few Mods....
    Quoted from autozone.com:
    KELLY_SPRINGFIELD 945K6 $18.99
    GATORBACK 4060945 $24.99
    I have the standard belt (945k6) installed on my 96 3.8 for over three years now, and it's still in excellent shape.
    If I was to rate the belt installation on a scale from 1 to 10 (1 being the easiest and 10 being the hardest) I'd say this project would be a 1. All you will need is a 1/2" ratchet-drive to put on the tensioner then slowly turn to loosen the belt, and a diagram of the belt routing which should be on a sticker under the hood.
    Thats it, nothing else to it! It takes me about a minute or two to replace my belt.
      thanx i appreciate it i will have to tackle this this week
      1997 Camaro LS1 RS
      1994 Camaro - Sold
      A Few Mods....
        I replaced mine maybe 2 years ago and still looks good.
        1 wrench and about 5 minutes if you know what your doing (how to wrap it).
        \'01 Mineral Grey SVT Cobra<br />-former F-body owner
          i have a gatorback and i havent had any issues with it
          2003 Chrome Silver Nissan 350z 6 Speed<br /><br />2001 Bright Rally Red Camaro 3800 M5-----SOLD but missed
            Last summer I had underdrive pulleys installed on my car and had to replace the belt with a different one of course and now less than a year later the belt has 4 out of the 6 ribs almost completely worn away while the other 2 are almost perfect. It has to be from the new pulleys somehow but I thought it was weird for it to wear that way. They were ASP pulleys. Anyone else see anything like this before?
            Newfoundlands Camaro & Firebird Enthusiast Site<br /><a href=\"http://www.nf-fbody.com\" target=\"_blank\">www.nf-fbody.com</a>
              I bought a gatorback a couple months ago....great belt. Its well worth the money.
                most likely ur pullies are out of alignment
                1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
                  i got the kelly springfield from autozone and, although it works great, i did notice it was louder then the one i had.
                  97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
                    belts will be alittle bit louder when they are new until they break in after a few hundred miles
                      That's what I assumed too but I just thought it was weird that the whole belt didn't wear out opposed to only those 4 ribs. That's what I get for bringing the car to a garage to install them I guess :rolleyes:
                        Re: Serpentine belt replacement need sugestions
                        Replace mine and in 10 miles it was shreded to pieces. Anybody had this problem? Thanks.
                          no sorry. check your pullies
                          1997 Camaro LS1 RS
                          1994 Camaro - Sold
                          A Few Mods....
                            Either it was a wrong size too tight or wasn't set in the grooves on one of the pulleys and shreded off. If stock and no A/C deletes I bet it wasn't set in the grooves right or lined up.
