Have No Heat - FirebirdV6.com/CamaroV6.com Message Board
Have No Heat
  • Have No Heat
    If anyone can help I have been working on my buddys 1994 Trans AM 5.7L, I thought that his thermostat was stuck open so I changed it. Now he has little more heat than before but my question is what else can be causing his car not to have heat, and also when he accelerates he loses his heat..........Please Help
    Things done so far: New Thermostat, New Radiator,Coolant 50/50 mix Air was bleeded out of system
    I swear this os [img]graemlins/bs.gif[/img] and i am :mad:
    1995 Chevy Camaro 3.4L<br />K&N air filter<br />Centerforce Dual Friction CLutch<br />Flowmasters 3\' pipes<br />Pioneeer Sound System
    Could have a clogged heater core.
    Is he having cooling problems?
    <b>LS1 RX7! </b> &#0124;&#0124; <a href=\"http://www.no-bling.com/image_galleries/index.php?action=viewgallery&gallery=galleries/eyeoutthere_LS1_FC\" target=\"_blank\">Full Gallery</a> <br /><br />LT1 Header Informtion/survey
      Check the vacuum driven components on your AC system.
      You can achieve anything for which you are prepared to pay the price.<br /> --ATTILA THE HUN
        Flush the radiator. When you changed the stat you got air in the system. flush and bleed the system.
        94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
          ok i have flushed the radiator system got all the air out and he is not having any problems with the cooling system, what else can it be ??
          it starting to get cold in chicago please help
            Seriously, check the vacuum controlled side of the hvac system. There is a door in the duct system that is usually moved by a vacuum controlled actuator. This door determines whether or not air passes through the heater core. You may have a dry rotted fitting that is seeping vacuum, and the actuator/door may not be functioning correctly.
              whats the temp on the stat? if its a low temp stat, it could take a lot longer to heat up...
              \'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
                <blockquote>quote:</font><hr>Originally posted by apiccola:
                Seriously, check the vacuum controlled side of the hvac system. There is a door in the duct system that is usually moved by a vacuum controlled actuator. This door determines whether or not air passes through the heater core. You may have a dry rotted fitting that is seeping vacuum, and the actuator/door may not be functioning correctly.<hr></blockquote>I'm with appacola on this one - I have seen it happen many times - the air is not properly directed because the doors are not being fully actuated. The most likely location for a vacuum leak that will cause this type of problem: in the lines to or from the vacuum reservior. GM uses very thin, stiff, spagetti line. It can be replaces with the regular rubber line; the fitting match.
                ...it\'s lonely out in space...
