I think it is the crossmember...the dohicky that is half way down the center of the car and the exhaust and DS run above it. I need to lower it down a little so the exhaust stops hitting it....anyone know the size washers I need to move it down a little?
Crossmember????
Crossmember????
Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>Tags: None
so what does it do exactly?Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
Actually, it adds reinforcement to the floorpan and the driveshaft tunnel. Somebody at GM decided that it was worth the effort/expense to put one on your vehicle in the first place; I'm not entirely convinced it's a good idea to take it off.
I think BMR makes an aftermarket brace for about $90 or so that only weighs about 12 lbs.... if memory serves. It usually doesn't.
Long time no see cardiac. :cool:╓<br />║ Matt M<br />║ <a href=\"http://home.austin.rr.com/morrism/3800/sunset_logo2.jpg\" target=\"_blank\">Down with the Sixxness</a> <br />║ Polo Green 1995 3.8 Camaro<br />║ intake, cat, catback, shocks, 3.42\'s, and 12\'s in the trunk<br />╙
im not sure how much bracing it could do... i bent mine almost in half by hand (im not a big guy at all)
from what ive heard apparently it functions kinda like a driveshaft saftey loop, if you were to drop the d/s from the tailshaft then it wouldnt let the d/s hit the ground and pole vault the car, im not too concerned with that though, so i removed mine-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
[quote]Originally posted by user1101:
[qb]Somebody at GM decided that it was worth the effort/expense to put one on your vehicle in the first place; I'm not entirely convinced it's a good idea to take it off.
I left mine in place.
Originally posted by StudlyCamaro:
im not sure how much bracing it could do... i bent mine almost in half by hand (im not a big guy at all)1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
OK, so back to my original Q....what size washers do I need to use as a spacer?Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
