Originally posted by Wicked 3800 V6: I used the bleed-screw-hole on my thermostat neck. Reads after 160ish for me. [img]smile.gif[/img]
Or you could install a T fitting underneath your TB in the stock temp sensor hole.
Thanks for the info. [img]smile.gif[/img]
I didnt think about using the bleed-screw hole or T fitting. Ill have to try and let it get up to tempature, I just hooked it up and saw it didnt read anything and unhooked it. So maybe ill try and see if the GM sender works when the engine gets up to temp before I try the cyberdyne sender.
