diference between start switches - FirebirdV6.com/CamaroV6.com Message Board
  • diference between start switches
    Hi
    The start switch located on the column of the steering wheel has died on me, the problem is the gm goodwrench only has for the standard and mine is auto. Not available on autozone or pepboys. Looking at both parts look the same but the std has diferent part number, so no option, had to go with it, are they internally diferent?
    thanks for any help.
    know when to go wot, and when to just enjoy the ride
    Looking at my parts manual, I see 1 part number regardless of engine/transmission. It does change depending on the chip in your key, though.
    Matt
    1998 Mystic Teal Camaro M5
      I'm refering to the switch located under the instrument pannel, the guy at goodwrench could had made a mistake
      thanks
        OK, I thought you were talking about the key cylinder. The switch itself is different for Manuals and Autos. I'm not sure what the difference is. Probably has something to do with the clutch interrupt for Manuals and Park Lock for autos.
        Matt
          the pins on the both switches are the same, from outside shure look the same, i'll have to try becouse culd't fint the part for the auto.
          I'll tell you how it turns out.
          thanks
