do coil packs ever go bad? - FirebirdV6.com/CamaroV6.com Message Board
  • do coil packs ever go bad?
    my car has 100,000 miles on it
    think i need to replace them?
    1993 240sx 5 speed, Super Hicas, LSD, Stock for now<br />Sold-1995 Red T-Top 3.4 Camaro<br />Totaled-1997 Jade Green Cavalier 2.2 auto
    yes coil packs do go bad, i just replaced mine at 98,000 so you should probably replace them now, expecially if you are having problems with the ignition system.
    Justin96Bird / Justin98TransAm<p>1998 Navy Blue TransAm<p>Whisper Lid<br />free ram air<br />K&N Filter<br /><a href=\"http://www.hhbc.com/justin96bird/index.htm\" target=\"_blank\">DynoMouth Exhaust</a><p><a href=\"http://www.hhbc.com/justin96bird/index.htm\" target=\"_blank\">http://www.hhbc.com/justin96bird/index.htm</a>
      where can i buy some?
        Good ol' Auto Zone, I think I paid like $33 bucks for one coil pack. Mine went bad and caused misfires really bad with 2 of the cylinders (each pack fires 2 cylinders). So you'll be looking at like $100 bucks total - aftermarket coil packs aren't too much more I don't think - are they?
        1999 Black Trans Am A4<br /> <br />-Flowmaster with Flowtech Cutout <br />-SLP Lid <br />-SLP MAF <br />-Ported Heads, hardened pushrods<br />-Diable Sport Programming<br />-18\' ZO6 Polished rims
          any local auto parts store should have them, I think i got mine at Discoutn Auto Parts for like $25. I had to replace one at 65K. Cylinders were misfiring
          <a href=\"http://bellsouthpwp.net/d/e/defrag/sig.jpg\" target=\"_blank\">1997 Firebird V6-Y87/W68</a>
            If you want to, for like $7 extra per coil pack you can order the new MSD coil packs for our cars. $39.95 each, part number MSD-8224 on summitracing.com (they are on backorder but they are still availiable)
            C. Boney<br />1997 Firebird 3.8L V6<br />---------------------<br />Modifications:<br /> <br /> SLP Cold Air Induction, Ported/Polished Throttle Body, Carsound 3\" High Flow Cat, Sweet Thunder 24\" Chambered Muffler, Removed Rear Exhaust Section, Custom Fan Switch, 35th Anniv. Silver Stripes, Old T/A-Style Silver Sail Birds
              You can test your coils. Take the 2 plug wires off one coil and start the engine. The coil should be able to arc from 1 post to the other. If it doesn't, it is weak. Do this for all 3 coils. BUT DO NOT RUN IT LONG WHILE PERFORMING THESE TESTS. Also, DO NOT touch the spark. DIS will bite you MUCH HARDER than a standard ignition coil.
              Dan<br />1990 RS 170,000 miles<br />3.4L collecting dust<br />700R4-to-T5 swap completed on Dec. 13, 2002
                <blockquote>quote:</font><hr>Originally posted by Dan90RS:
                You can test your coils. Take the 2 plug wires off one coil and start the engine. The coil should be able to arc from 1 post to the other. If it doesn't, it is weak. Do this for all 3 coils. BUT DO NOT RUN IT LONG WHILE PERFORMING THESE TESTS. Also, DO NOT touch the spark. DIS will bite you MUCH HARDER than a standard ignition coil.<hr></blockquote>
                DO NOT DO THIS!!!
                you may damage the coil and/or the ignition module. when dynamically testing an ignition component, use either an inductive pickup to see peak firing kv, or use a spark tester available for like $2 at autozone.
                  Not to mention you can damage your engine by forcing knock.
                  1995 Camaro 3.4 v6. Dead<br />1995 Trans Am FIPK.
                    <blockquote>quote:</font><hr>Originally posted by zlightning:
                    Not to mention you can damage your engine by forcing knock.<hr></blockquote>
                    how so?
                    you'd have misfire on both cylinders but i dont see how you'd have spark knock.
                    spark knock is when the spark happens too early when the piston is on its way up (compression stroke.) it is due to overly advanced ignition timing, excessive compression, or excessive heat in combustion chamber. killing ignition to 2 cylinders by shorting the coil won't cause this.
                    spark knock (aka detonation) will cause different adverse effects on the engine components than an ignition misfire.
                    [ May 12, 2002: Message edited by: strange_trp ]</p>
                    • 187shark
                      by 187shark
