I have a 3.1 and the tensioner only had 2 bolts holding it on. It was a little dificult to get to one of the bolts but I just used a 10mm hand wrench to loosen it up.
It's been a while since I changed mine but I think you have to hold the tensioner out of the way with one wrench and remove the bolt with another. I'm not sure about that. I remember having to get my roommate to help me.
95 Camaro 3.4L A4<br />Bosch plugs/MSD wires, K&N FIPK , Magnaflow catback, hi-flo cat, B&M Shift+, Dee\'s spacer<br />Kenwood KDX-859, eXcelon Amps, Infinity Kappa 3-way doors and Perfect10 sub<br /><a href=\"http://www.cardomain.com/id/harbins95\" target=\"_blank\">Behold, the raw fury that is known as the 3.4!!!</a>
