pcv valve trouble! - FirebirdV6.com/CamaroV6.com Message Board
pcv valve trouble!
  • pcv valve trouble!
    just went to replace the pcv valve... and the gasket the goes in between the cover is broke...
    napa doesnt have a clue what im talking about... what shoul i do...
    where can i get one?
    White 1998 3.8L Camaro
    Home Ram Air / Free Flow Intake
    Drilled / Slotted Rotors with black painted Calipers
    I got mine at the dealer...no parts store had one.
    1999 Y87 Camaro<br />Whisper Lid, SLP SS Takeoff Exhaust
      CALL IT A PCV GROMMET.... THAT MAY HELP THE PARTS STORE DUMMIES... LOL
      **2002 convertible firebird - SORTA modified<br />**1964 chevy nova (straight 6/320hp)<br />**2002 v-star
        ok, no where has one, looks like itll have to do until wed when they get it...
        it seems to be fine, only a slight leak is audible...
        they said it should be fine until i replace it...
          another question...
          where is the fuel filter located?
          and, do i really need to purge the fuel lines, or will opening the gas cap work?
          can a mod change my topic to fuel filter question (so i dont have t make another)
          thanks
            the fuel filter is on the frame rail at the rear of the car on the left side right by the wheel. and YES you will need to releave the pressure on the fuel lines or you are gong to get a face full of GAS and that ain't good.
            Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
              open the gas cap and open the shrader vavle on the fuel rail (pass side) unscrew the cap and push it like you would deflate a tire
              www.turbov6camaro.com
              1997 3800 Series II Camaro
                But put a rag over the valve in case fuel squirts out.
                  will i have to do anything to re-pressureize the fuel lines?
                    When you changed the filter, put the car in the on position and let the injectors prime before you start it. That will get the pressure back up.
                    1999 Grand Prix GT<br /><br /><a href=\"http://www.fishsgt.com\" target=\"_blank\">www.fishsgt.com</a><br /><br />Best ET: 14.94@91.25MPH with a 2.2 60\"
                      As for the gasket issue, you can buy a sheet of gasket material and make your own. That's what I did for my 3800 when my old gasket broke because it was so brittle. Still works fine.
                      Check out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
                        i did it without putting the rear on jack stands...
                        i had the front on stands to change my brakes.
                        i opened the gas tank... and there was no pressure at all in the fuel line... cause no gas sprayed out...
                        is that normal?
                          is that normal?
                          well there should be at least some fuel
                            there was no pressure... when i pushed the pin in, none came out
                            it did trickle when i disconnected it.
                              if your car was off for a while the the pressuer does escape
