I just got a new 1999 red camaro off a lot and was curious to see what kind of gears it has. I know to check the rpo codes but I can't find them on the door or in the glove box where the should be. Are they anywhere else, or is there any other way of finding them?
RPO codes
According to the specs on this site the car would have 3.08's unless the car has some kind of performance package. A guy I know has the W68 package and 3.42's came with that. You can tell what they are by jacking up the car and turning the wheels too and then taking note of how many times the driveshaft spins around per one rotation of the wheel.Newfoundlands Camaro & Firebird Enthusiast Site<br /><a href=\"http://www.nf-fbody.com\" target=\"_blank\">www.nf-fbody.com</a>
Y87 MUST be on the sticker to be a TRUE Y87 car.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by skatr:
is there any definite way to tell if its y87 or not. i got ground effects and a spoiler so I think it is?
http://tech.firebirdv6.com/y87.htmlMatt
1998 Mystic Teal Camaro M5
Do a burnout. If both tires spin you got LSD with 3.42's. 3.42's only come with LSD.<a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
no i have an open with 3.08s and when i burn out in my drive way, good traction level ground, both tires will spin one time it did in the street though but just because both tires spin doesnt mean its lsd oh yea if its y87 sometimes the top half is black like the windshield stuff like a z but if you have ttops its differentif i was a pirate noone would have a car
If you're assuming you have an LSD because both wheels spin on the street then as mentioned above that may not be the case. Again jack the car up on one side only and try and turn the wheel... if it moves you don't have an LSD. W68 is a sport appearance package... it comes with ground effects, fog lights, dual exhaust, etc. But my friends W68 had stock 3.42's with an open differential.Newfoundlands Camaro & Firebird Enthusiast Site<br /><a href=\"http://www.nf-fbody.com\" target=\"_blank\">www.nf-fbody.com</a>
Y87 can come with a black roof (like the Z) and t-tops too, at least mine did.
Check your rear axle too, if you have disc brakes, you have the Y87 rear-end off the Z28.1996 Camaro Y87 5-Speed<br />K&N filter<br />15.19 @ 89.84
the rpo codes should be on the drivers side door,like in the door jam kinda.do you have dual exhuast?.( if its still stock )1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
I don't know what year disc brakes became standard but every F-Body I know of 95 and up has disc brakes in the rear.Newfoundlands Camaro & Firebird Enthusiast Site<br /><a href=\"http://www.nf-fbody.com\" target=\"_blank\">www.nf-fbody.com</a>
