I was thinking about working on the car and found this spare tire hole. I dont know if it's supposed to be there. Has anyone found out the purpose of it? I want to cover it up. Here's a pic with my hand shadow over it to show you the hole in the spare tire well.
i gots one too. I remember a discussion about it a while back and someone kept ice in there or something while at the track and it turned in to a huge argument about it draining and being unsafe. I think it was mustangeater but dont quote me. Anyway yeah they said it was for some kind of draining of moisture.
Anyone ever think its for venting, like when someone closes the hatch when you are sitting in the front seat with the doors closed, there's some kind of pressure in the car.
Originally posted by joecool: Anyone ever think its for venting, like when someone closes the hatch when you are sitting in the front seat with the doors closed, there's some kind of pressure in the car.
theres a plugged up larger hole under each rear seat for the same thing..drainage..in case of a flood, leak, whatever..i only had the rear half of the carpet removed..there may be some in the front too
actually you can use your camaro as a pool,fill her up with water then swim some.after your done just remove the plugs for drainage [img]graemlins/rofl.gif[/img]
