How hot does your car run? - FirebirdV6.com/CamaroV6.com Message Board
  • How hot does your car run?
    How hot does your car run?..say your sitting at a red light like for 5 minutes or going through the drive through?
    I have a 94 camaro 3.4, and if its stopped like for 5 minutes it gets almost to the red.
    And driving it, it goes half way up...
    I dont know very much about 4th generation camaros...so any responces will be grately appreciated.
    Thanks in advance!
    My car has GPS trackin\',traffic alert,its own phone #,PS2,screens. And What da H3ll,When I Turn da key it says \"You\'ve got mail\"..... <br />I swear and promise.. I\'ve had more cars then Charlie Thomas.. bounces in a Monte\' that hopped.. Pimped old skoo Blazer on Chopz, Today Its a Camaro at all da plya spots.
    I get about 210 at the hottest, but I usually turn my man fan switch on after that. Driving I'm at about 175. I had my stock thermostat replaced, I have no clue if it is a 160 or what, but all I know is that my car runs pretty cool.
    <a href=\"http://www.cardomain.com/memberpage/512325\" target=\"_blank\">2004 Silver Impala</a> Faster than my Firebird<br /><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=282862\" target=\"_blank\">3.4L Red 1995 Pontiac Firebird</a><b> For Sale</b>
      just replaced water pump and switched from dex-cool to reg coolant and i never go over 200 now
      1991 firebird - sold<br />1994 camaro v6 - lady ran red light<br /> *totaled*<br />1996 Camaro v6 RS sport package 5 spd - 8mm wires/ platinum plugs, z28 clutch@assembly, powerslot rottors, hiPo brake pads, hiPo power steering pump, larger tie rods and hubs, 1le tranny mounts
        Does seem it is running a little hot especially while sitting. While it is sitting and the temp goes up, check to see if the radiator fan(s) come on. If the fan(s) does not come on then that is most likely your problem.
        2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
          With fans on while on the expressway: Water - 160 degrees, oil = 220 degrees (in hot weather).
          With fans on in city streets: Water - 160 degrees, oil - 270 degrees.
          In cooler weather, the oil stays pretty much at about 180 degrees which is where the car feels like it performs the best.
            mine runs about 140 on a hot day [img]smile.gif[/img] guess thats prolly cause i got the 5.7L V8 IN MY TRUCK, mine runs so much cooler cause i installed a 160 thermo and if you ever look in a 94 engine bay ull see there is absolutley nothing in it so it has LOTS of room for air flow, too bad camaros are so jammed in there, but stock thermo is 195 so ur good all the way to 210
            94 chevy truck - SOLD!!<br />92 toyota tercel - beater SOLD!!<br />88 Rx7 se - SOLD !!<br />88 MAZDA RX7 CONVERTIBLE NOW
