I had a similar sound coning from my pulley system...Eventually an idler pulley sripped the bearing inside of itself, causing it to seize and throw my belt. It's an easy fix...they sell them at Autozone, O'Reilly...etc. for around 15$.
1997 30th Ann. Camaro RS <br /><br />Aluminum CAI, Magnaflow Cat-Back, Magnaflow Hi-Flow Cat., 160 Thermo. <br />B&M Shift Plus, Taylor 8mm Spiro Pro Wires, NGK Iridium Plugs
