whats up guys....has anyone had any problems with their headlights not coming on. i have the drl so they come on automatically...anyway i start my car and all the lights come on except my HLs and every 30 secs or so the volt gauge drops almost in the red then goes back to normal. I can also hear a click when it happens coming from the either the HL switch or the fuse box. i had to drive home with just my fog lights blazing. i didnt see a fuse or relay for the HLs so any help is appreicated.
headlights on 2k camaro wont come on!!
You've got something shorted somewhere. There's an automatic circuit breaker somewhere in the system. Did you do the foglight mod? When I did mine on my new Camaro, my silly a** grounded the wrong wire, and when I turned the brights on, the headlights went out, and it kept doing what you were describing. Oh yeah, are the dome lights also dimming when you try to turn them on?Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
yeah you got something shorting out somewhere.. the clicking sound is the breaker getting thrown.. then resetting.. then getting thrown again.. time to start tracing some wires..
you should be able to find a diagram at..
alldata.com
[ September 12, 2002: Message edited by: black98V6 ]</p>-Brad
2000 V-Star Custom 1100
:rock:
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
