revs drop, when gas is tapped in neutral - FirebirdV6.com/CamaroV6.com Message Board
  • revs drop, when gas is tapped in neutral
    ok, i have a 3" cat/catback, and CAI.
    but, i've noticed that when in neutral (stopped), when i tap the gas, sometimes the revs kinda drop a little, go up, then fall down to 500 rpms, then back upt to hte normal 900 rpms at idle again...
    is this a normal thing? i recently had my plugs/wires changed, have cleaned the air filter, new fuel filter, new pcv valve...
    all i have left to do, is i guess check the o2's, clean the throttle body, and clean the IAC sensor..
    any words of advice are greatly appreciated
    97 camaro<br />black, 5 speed, t-tops, rockford fosgate cd w/4X6.5\" rockford speakers, 3\" flowmaster american thunder catback with 3\" carsound cat, SLP CAI, B&M Ripper w/leather Hurst shift knob, 5% tint.<br /> <a href=\"http://camaroz28.cardomain.com/id/ianwells100\" target=\"_blank\">http://camaroz28.cardomain.com/id/ianwells100</a>
    Mine does this ever so slighty...but not to the extreme of 500 RPMS Mine only goes down to about 800-850 or so...and thats after the rev...it drops below normal, then rests at 900...
      most of the time, it goes down an ounce, as you say, but when i tap it say 3 times in quick succession, it drops down a lot...
      i wonder if its a sensor that needs to be cleaned/replaced, or something like that... if anyone knows, i'd greatly appreciate the help (although, really, its no biggie... i'm just anal about things that aren't 100% right in my eyes)
