More signal troubles - FirebirdV6.com/CamaroV6.com Message Board
  • More signal troubles
    I am having trouble with my turn signals after going through a car wash
    Well upon advice i replaced all my bulbs and still no dice
    yet when i put my hazards on everything does work, its only the turn signals that dont... any ideas?
    99 3.8 Camaro (M5) Y87
    Sounds like the flasher....its located under the dash....the turn signal and hazards are different flashers....its a small roundish unit that is clipped in on the right side about 6 inches from the instrument cluster
      Thanks- ill give it a try in the mornin!
        Bro, i just had the same problem with mine...i just went and picked up a 3 dollar flasher from R&S, and replaced itin the parking lot. It took like 2 minutes.The flasher is right behind the knee bolster on the driver's side of the car...its held in a little "U-shaped" holster surrounded by like a thousand wires. Just unplug the old, and re-plug the new...and ur set to go.
