my ac leaks water inside my car, the passenger floor is soaked. Is there something wrong with my ac or is there a drain pan to catch the water. Help
ac leaking
sounds more like your heater core. pick up a haynes manual, they go through the process of checking it and pulling it out. It actually doesnt look like as bad a job on our cars as it is on some.\'01 Mineral Grey SVT Cobra<br />-former F-body owner
Verify if the fluid on the floor is coolant or water. Use a paper towel to soak some up, and you'll be able to tell if it's red or green (coolant, depending on what you have) or clear (water). If it's just water, then your AC drain might be clogged. There is probably a drain tube on the firewall somewhere. I have not looked for one on mine yet, but I'm sure someone here can tell you where it is.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...12 hours ago
