Coolant/oil leaks - FirebirdV6.com/CamaroV6.com Message Board
Coolant/oil leaks
  • Coolant/oil leaks
    My major problem is that’s oil somehow gets into my coolant, also car losing the coolant, and there is no leaks. Last week I found wet spot on the rear passenger side of the engine block, around head gasket area. Mechanic at the local shop here said that it is Head gasket leaking and they needs to be replaced.
    I’m almost ready to do that , just need a second opinion from you guys, Maybe radiator stop leak could fix that [img]smile.gif[/img]
    Unfortunately, that sounds right to me. I don't think radiator stop leak is gonna help much. You could try.
    Or you could clean it up, change the oil, change the coolant, and sell it. Fast.
    Oh, and sell me your LSD.
    \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
      [img]smile.gif[/img] Well thats would be very bad.
      For the LSD-definitely get it! It is best drivetrain upgrade. Traction like 100 times better. After you get it youll realize how open suc k!
      ps. I got mine real locker(not some sort off spring loaded)off chevy Blazer for 200b
