and NO not the 'I drank lots of beers followed by a ton of Taco Bell' stuff. My question is what is the best grade to run on a N/A 3.4? I've heard our engines are best on low octane but then I've heard they're designed to run premium. Someone wanna resolve this.
Ack- Taco Bell...harming senses...eyes watering...nose on fire...parakeet dieing...
<b> \'95 Camaro 3.4L A4 <i>Rikku</i><br />AutoX - Drift - Street </b><br />\"Sideways is faster.\"
You can use 87 with no problem if you don't have much in the way of mods, it's only 9:1 compression. However, if you have enough done that you're getting a pretty hot burn (lots more air and hotter spark), then you're looking at detonation and resultant knock retard at the top end. In that case, try 89 first, and then try 91.
When I had my 3.4, I had the K&N filter, Accel coils and wires, the air box opened up, and the noise baffles removed, and I was getting knock retard (from detonation), which resulted in the car taking off strong, and then at about 4500 rpm, it felt let the throttle dropped off a bit, then picked back up at about 5000rpm. Switching to 91 (92/93 in other states) got rid of that.
So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...
