Coolant amount? - FirebirdV6.com/CamaroV6.com Message Board
Coolant amount?
  • Coolant amount?
    Does anyone know the exact amount of coolant used when chaning it? I looked for this in the manual and couldn't find it. I searched here and couldn't find it.
    Thanks, <br />JAM<p>02 Firebird GT
    2 quarts water. 2 quarts dexcool.. 50/50 mixture
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
      Thanks! I know it is a 50/50 deal, but only 4 quarts total? It seems like there would be more.
        There is more, but I'm not sure of the exact capacity cuz I've lost my owner's manual somewhere. I was curious about that myself.
        2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
          Yeah, I'm gonna have to dig through my owners manual to see if I can find it. I need a close to exact amount because I want to add some Royal Purple Ice addative and you have measure it. :D
            it took 4 quarts total to FILL my radiator..
            then start the car.. open the bleed valve. as the water pump pumps the fluid through the car.. you can add more water. top it off.. cap it. wait till the thermostat opens so the bleed valve starts spewing out coolant, then close the bleed valve..
            done..
              Ok, I found my owner's manual. The capacity is 11.4 quarts for an automatic or 11.6 quarts for manual trans.
                [img]graemlins/bs.gif[/img]
                unless i have a REALLLY SMALL radiator
                  just use an antifreeze checker. then check what temp you should be safe with. cant go wrong there.
                  96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />&gt;&gt;&gt;15.375 @ 89.27&lt;&lt;&lt;NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
                    Hey Tyler, you can wave your stupid little flag until the Titanic resurfaces, or you can look it up yourself. My owner's manual (2000 Firebird, auto trans.) says the cooling system capacity is exactly the numbers I listed above. And after the last time I flushed mine I know it holds more than 4 quarts, so I should be the one waving the flag on you.
                      LOL
                      Thanks for the help!! 11 and a half sounds about right.
                        Hey, no problem, anytime. And for the record, my previous statment was NOT a personal attack. It was strictly in self-defense haha
                          now that is funny... i gotta use that... 11.6 sounds about right for TOTAL in the whole system...
                          !! Drive it like you stole it !!<br /><br />I believe forgiving them is gods function, our job is to arrange the meeting <br /><br /> <a href=\"http://www.azclubgp.com/garage.php?mode=viewgarage&u=202\" target=\"_blank\">2002 GTP 40th Anniversary Edition Sedan</a> <br />-------------<br />Mods:<br />3.4\" Pulley<br />rigged K&N Filter<br />14.3 et
                            ok.. in total defense.. the RADIATOR holds 4 quarts.. . check out install university for yourself.. actually.. i'll help you out.
                            I would LOVE to see you try and fit 11 quarts in the radiator.
                            maybe if you would learn how to read you would notice i said.. "AFTER YOU FILL THE RADIATOR.. START THE CAR, AND OPEN THE BLEED VALVE. THEN REFULL RADIATOR AS NECESSARY. WHEN THE THERMOSTAT OPENS, IT WILL PUSH ALL THE AIR OUT OF THE BLEED VALVE. THEN CAP THE RADIATOR AND CLOSE THE VALVE."
                            god damn... :rolleyes:
                            and just for the record... install university used 4 quarts exactly in their radiator on their LS1.. which is slightly larger than our 3.8's radiator..
                            http://www.installuniversity.com/ins...ostat_swap.htm
                            go about 3/4 of the way down.. you'll find the correct answer.
                              done..
                              rookies... :rolleyes:
