Ok, I dont understand this...after changing my plugs, my Service engine light came on..it backfired when I gave it WoT..then stalled...so I turned it off..made sure wires were in correct firing order...made sure boots were all the way down. turned the car back on,no more backfire..still stalls...engine light still on..so I back it out..and put the gas to the floor, and haul *** all over the place..finally light goes off..and I manually shift (its automatic) light comes back on, so I turn it off...let it sit for a bit, turn it back on, Light is gone...haul around a bit more, light comes back on, goes off..and now is finally off and I think its going to stay off..but anyone know what would cause this? I put in higher end plugs and wires..maybe the computer was adjusting? My car runs fine now..I'd just like to know what was causing it to be so wierd for a little bit there..any clues?
Service Engine Light?
Did you checking the gapping of the plugs before you installed them?94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
There is no adjusting for higher end plugs or wires.
What is the code you are getting?
[ September 12, 2002: Message edited by: CARdiac ]</p>Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
<blockquote>quote:</font><hr>Originally posted by CARdiac:
[ September 12, 2002: Message edited by: CARdiac ]<hr></blockquote>
In most cases you shouldn't but it's always good to check!!!!!!!!!!94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
Welcome to the 3.4L SES club. I've been driving around with the same ones for 4 years!!! But, my problem is the EGR valve.
Is it idling rough? Does the whole car shake?
The next step towards solving this problem is going to be getting it scanned. I believe AutoZone does this for free. Your car stores the ten most recent trouble codes(somebody correct he if I'm wrong). I'd go get it scanned while they're still around.
Good luck.95 Camaro 3.4L A4<br />Bosch plugs/MSD wires, K&N FIPK , Magnaflow catback, hi-flo cat, B&M Shift+, Dee\'s spacer<br />Kenwood KDX-859, eXcelon Amps, Infinity Kappa 3-way doors and Perfect10 sub<br /><a href=\"http://www.cardomain.com/id/harbins95\" target=\"_blank\">Behold, the raw fury that is known as the 3.4!!!</a>
<blockquote>quote:</font><hr>Originally posted by Harbin1:
Good luck.<hr></blockquote>
Hey, I finally solved the 3.4 EGR dilema. Email me to discuss.Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
