Fuel pressure regulator tool - FirebirdV6.com/CamaroV6.com Message Board
  • Fuel pressure regulator tool
    Hey everyone,
    This is my first post here, I've been lurking for awhile and I like what I see [img]smile.gif[/img] . I have a 1994 3.4L Camaro that is storage for the winter back home in Indiana. Anyways went home to check on it and found that I will need to replace the fuel pressure diaphram. My question is, what is the correct tool to remove the screws from the top of the regulator? I did a search and could not find anything.
    Thanks,
    Derek
    You will need a torx bit, but it will have to be one that has a hole in the middle of it. I bought mine at Autozone as a set. Make sure that it has the hole or else it will not work correctly.
      Hey Viper thanks for the help, I'll pick up a set when I get home, and then swap out the diaphram, hopefuly that will cure my problems.
      Thanks,
      Derek
