Well, I searched the posts in this particular section of the forum, and found a lot of useful info. However, I wanted to see if there were any more opinions or if anyone with this problem found a solution.
I have a 1999 Camaro M5 3.8L. Under partial throttle, the car does not stutter (vibrate) but it is more like a violent hiccup. I'm going to try plugs and wires first to see if that does not solve the problem as it might possibly be a leaky wire, and then maybe the coil pack. All of these components look to be stock and the car has 56K on the clock.
My question is- are there any other ideas as to what this could be? I replaced the fuel filter and PCV valve when this first started to happen with no change. I also ran a few bottles of injector cleaner through the system as well. The car idles fine other than the occasional small shake, and it will cruise smoothly all day. Thanks for the help.
