Burnt Starter Up (Need Help) - FirebirdV6.com/CamaroV6.com Message Board
  • Burnt Starter Up (Need Help)
    Ok so basically i burnt my starter up. Basically this happend from a coolant spill when i was changing my coolant and got everything wet. im guessing i got the starter wet and wasnt doing anything when i was trying to start the car. its tarted tro make a bad smell though. i dried everything off real good again and let it sit then it would start again just with some whining sound. now it doesnt like to start very often so im going to replace the starter.
    ok i was looking on gmparts direct and im confused of what i need to buy.
    do i just need the starter assembly?
    1994 White Firebird 3.4L A4<br />Mods: K&N CAI RKSport Headers & SLP Loudmouth Cat Back <br />1969 Mustang Mach 1 351C M4<br />Mods: None yet......<br />~ Ryan
    nm i figured it out
      A coolant spill won't burn your starter out. Your starter gets wet everytime you drive in the rain...right?
      What do you mean when you say "it's making a whining sound?" Is it the starter making the sound, or is it after the engine is running?
      If your problem goes away after replacing the starter, then do worry about getting water/coolant on it. Just don't submerge it a large puddle or anything, and you should be okay. ;)
      -Marc
