Use the brake booster line. Find your master cylinder, and look at the hose right behind it, stick a small funnel in there and pour about half the can at a decent slowish pace.
94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
Master cylinder as in your brake fluid resivour (The place you put brake fluid in). You can miss it, it's toward the back right of the engine (Facing the engine standing at the front of the car). You'll know it's the right hose when you take it off because it will shoot the RPMS to 3k when it's running.
I got a 180 bc they didnt have 160*, If this isnt enough Ill go find one online or something. And now I have to flush my radiator, damn thing, when I opened the cap, there was this soft crud everywhere, time to change that out.
Also, my gauge still reads 210 inside the car, shouldnt it be reading below that line now?!
Ill have to seafoam it tomorrow, have to get goin to work.
