Oil Consumption - FirebirdV6.com/CamaroV6.com Message Board
Oil Consumption
  • Oil Consumption
    Hello,
    I have a 2000 camaro, 3.8 l that has approx. 45,000 miles on it.
    Every oil change (approx. 3,000) the car is a 3/4 to a complete quart low. No blue smoke and the compression test expressed the car is fine (no 10% or higher variance between pistons - all pistons w/in manufacture specs. according to the dealership).
    Mobil 1 synthetic has been used since approx. 5,000 miles. All oil changes, approx. 3,000 miles and I can count on both hands the number of times the rev limiter has been hit. The car is simply a daily driver (normal driving), typically shifted between 2,000 - 2,500 rpms.
    No oil leaks
    No real modifications other than a catback exhaust and whisper lid.
    Is this kind of mystery oil consumption normal for this motor?
    Thank you and have a good day.
    Dave
    youre burning/loosing oil somewhere. mine is pretty much right where i left it every time i change it. that oil isnt just disappearing
    once you fill your oil and check the level, ive found that if you run the engine for a min or two and then check it again it will go down that first time. after you change the oil and check the engine check it again and see where the level is on the stick, then fill it to where it should be.
    [ November 18, 2003: Message edited by: Loochy88 ]</p>
    Visit My F-Body Page
      Check the bottom of the engine and trasnmission, and see if they are coated with oil.
      You may have one of those new rear main seals that GM's been testing. It leaks oil out at a metered rate, so you just keep topping it off with fresh oil, and never have to do a complete oil change :rolleyes:
        Hello,
        The rear main seal is moist by the bottom of the motor/tranny is not coated.
        When I change the oil, it is typically a 1/4 of a quart above the full level....
        Maybe it does like to eat the synthetic oil? Two different mechanics can not figure it out....
        Tough one...
          mine consumes a full quart about every 3 months.... sux, never heard of it with the 3.8 though
