My passenger window, when i roll it up... it will go about 3/4 the way then stop.I then have to wait about 30 seconds then it will go about an inch, keep doing that over and over till it goes all the way up.
Has this happened to anyone else?
nope--window motor is going out. mine did that for about 3 months before the window completely stopped working. replace it now--it's not going to fix itself and it isn't a power problem.
1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
it's the motor, most people go thru this sometime or other. do a search and you'll find do it yourself instructions w/ pics for replacing the motor. you can buy the motor at autozone for $50 w/ a lifetime guaruntee. not a bad deal. should take a couple hours or less depending on how mechanically inclined u are [img]tongue.gif[/img]
<a href=\"http://www.cardomain.com/id/briansr\" target=\"_blank\">97 White Pontiac Firebird 3.8 A4</a><br />Mods- 2.75\" exhaust, Dynomax muffler, magnaflow cat, SLP CAI, Hypertech 160* thermo, Fan switch<br />Suspension-Kumho Ecsta 712\'s, 32mm/19mm sway bars<br /><br />Our Lady of Blessed Acceleration, don\'t fail us now. <br />-Elwood Blues
Guess I'll be replacing mine soon. My window goes almost all the way up, but stops about 2" from the top, and I have to wait a couple of seconds then it'll go up again.
My driver one is a little faster then the passenger one when the car is running but if it is only on accessory the passenger one almost stops, is there any way to save these things?
~chris~ 98 Cayenne red Camaro 3800 A4, 3:08, T tops Borla cat-back, wisper lid K&N, Bilstine shocks, Dunlops all around. <br />AOL IM: chevyboyz24
Mine started doing the same thing, it's a problem all 4th gen f-bodies have. If you are familiar witht akin off your door panel, you could easily do the swap start-to-finish in under 30 minutes.
