P121 and P122 codes - FirebirdV6.com/CamaroV6.com Message Board
P121 and P122 codes
  • P121 and P122 codes
    The p121 has something to do with throttle performance or something and the p122 is low voltage in the throttle positioning sensor.
    i cleared the codes and there hasnt been anything since, but im unsure about exactly how to check them both.
    and NO i will not just buy new ones to see IF they are the problem, its a waste of money.
    96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />&gt;&gt;&gt;15.375 @ 89.27&lt;&lt;&lt;NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
    http://www.diagnosticdialog.com/LookupCode.asp
    Trouble Code: P0121
    Vehicle Qualification: Chevrolet Camaro
    Description: TP Sensor Ckt. Insufficient Activity
    Trouble Code: P0122
    Description: TP Sensor Circuit Low Voltage
    ...sounds like you need a new TP sensor
      Here's the full diagnostic info for P0121 and P0122 (IE only). Both are problems with the TPS. It could be a couple things, but my bet would be on a bad TPS.
      DTC P0121 Throttle Position (TP) Sensor Performance
      DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage
      Matt
      1998 Mystic Teal Camaro M5
