Stupid O2 sensors.... need some OBD2 Help... - FirebirdV6.com/CamaroV6.com Message Board
  • Stupid O2 sensors.... need some OBD2 Help...
    Ok I recently purchased new o2 sensors for the left and right banks.... (In the manifolds...) because one of them went out....
    The one before the cat and the one after are still OE....
    Got some codes today....
    P0147 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
    Is this the BEFORE THE CAT sensor???
    P0153 - O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
    Is this the passenger side 02 sensor???
    P1153 - Something about right bank shifted lean.. I think this was cause by the bad o2 sensor anyways...
    WTF is going on with my o2 sensors????
    I took my cat back system off (right after the last o2 sensor) when all this happened.
    :mad:
    1997 Dodge Viper GTS
    Bank 1 Sensor 3 is after the cat.
    Bank 2 Sensor 1 is passenger manifold.
    P0147
    P0153
    P1153
    [ November 18, 2003: Message edited by: 98Camaro3.8 ]</p>
    Matt
    1998 Mystic Teal Camaro M5
      Yeah I got me one-a dem heeeetrrrr shirkit codes 2!
      I've heard either a light bulb or a large W small ohm resistor will do it. I'll update you around Jan or so when I get to it. Part of my !codes mods.
        or a good O2S with a good heating element maybe?
        you may want to check the ckt for the sensor as well as the heating element ckt. a fault in these ckts looks like a bad O2S to the PCM.
        • Andy H
          Transmission removal help!!
          by Andy H
        • 2.8 Bird
          Abs inop
          by 2.8 Bird
        • fishin
          by fishin
