I am sick and tired of my t tops leaking (we had like 2.5 inches of rain come by 2 times this week) and my car is leaking bad on one side. I put a towel on the seat which i folded like 4 times.
Any places on the net where I can buy weatherstripping??? Only my passenger side is leaking but would it be smart to replace both of them?
Anyways thanks for the help because i cant find any place to buy from.
<a href=\"http://www.cardomain.com/id/maleet\" target=\"_blank\">1998 Silver Firebird</a> <br />Basic mods... nothing real special but it sure looks good!<br /><a href=\"http://www.maleetpobanz.com\" target=\"_blank\">maleetpobanz.com</a>
Befor you go buying another set of seals, you may want to check the silicone seal on the bottom of your t-tops where they seal on the frame of the roof. Sometimes the rubber gets pulled up, breaks the silicone seal, and causes a leak...sometimes.
Where exactly is it leaking from?
As a temporary solution for next time it rains, place a large trashbag over the t-tops and weigh it down with something so it doesn't blow away. Looks like crap, but it'll keep the interior dry until the leak is fixed.
If its where the t-top receivers are, pull the t-top weatherstripping up slap some black silicone sealant under it and put he weatherstripping down it will get rid of all your leaks.
Make sure the t-top is setting in the little groove of the t-top weatherstripping.
Also I think www.yearone.com makes replacement t-top weatherstrippings, I think its $180 for both or $180 a side if I remember right.
It leaks right where the t top meets the part closest to the windshield... it comes dripping right out of that crack. Do you know what I mean?
I was on ebay today and didnt find crap. I suck! lol thank you.
you can try blowing air through the tube and see where the water is going.
Also you may have to adjust your front t-top bracket. Sometimes they need adjusting, they generally have shims in them from the factory and you can pull a few out to give a tighter seal.
