Auto tranny leak - FirebirdV6.com/CamaroV6.com Message Board
Auto tranny leak
  • Auto tranny leak
    I did a search but could not find this issue. Have a '95 Camaro that is leaking fluid. It appears to be leaking from a round unit at the rear where a wire attaches, speedo? Is this common & how do I fix it?
    Thanks
    vss. I think there's an o-ring for that. does it lok like THIS
    2013 Ram 1500 Big Horn
    94 comero 3.4
      Yup, that is it, but with a wire rather than a cable. What is it called? Trying to avoid sounding like an idiot at the parts store!
        Th o-rings on the vehicle speed sensor do leak sometimes, what you want to do is unplug it and make sure that there is no trans fluid where it plugs in. If there is then you need a new sensor.
        2005 Magnum
          So, you loosen the screw, move the bracket and remove the round device?
            that's about it
            2005 Magnum
