Ok, I had posted before that I removed my gas pedal and put on my neon apc pedals. The brake one works great, but I ****ed up the gas pedal for it feels that I'm not getting wot when flooring it. Thus, to be safe I'd like to get ahold of the gas pedal assembly. Including the pedal itself, the little spring and the rod that holds it all together, any info or gm part numbers would be greatly appreciated. Thanks!
Gas Pedal Solution!! Hopefully
~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>Tags: None
