OHV vs SOHC - FirebirdV6.com/CamaroV6.com Message Board
OHV vs SOHC
  • OHV vs SOHC
    Ok what is the difference between these I have been wondering for a while? Thanks.
    Alex
    1996 Camaro RS A4<br />Flowmaster 80 Series Muffler with 2.5\" catback and cutout, SLP CAI, BMR STB
    OHV = 1 cam, 2 valves per cyl, pushrods are used.
    SOHC = 1 cam per bank, 2 valves per cyl, no pushrods.
    DOHC = 2 cams per bank, 4+ valves per cyl, no pushrods.
    [ April 07, 2003: Message edited by: Dominic ]</p>
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      http://auto.howstuffworks.com/camshaft.htm
      ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
        <blockquote>quote:</font><hr>Originally posted by Dominic:
        <hr></blockquote>
        Correction:
        Single OverHead Cam still has 4 valves per cylinder. In fact, any overhead cam has 4 or 5 valves per cylinder.
        OverHead Valve just means there is a single camshaft that controls all the valves in the block of the engine, the camshaft lobes pushes the pushrods to move the rocker arms to move the valves open.
        Dual or Single Overhead Cams have the camshafts right above the valves, hence "Over Head" camshafts. Either one(single) or two(dual) camshafts above the bank of cylinders. The lobes of the cams are right above the valves, no pushrod needed.
        So, if it's a DOHC V6 there are 4 cams. If it's SOHC V6 there are 2 cams. DOHC I-4, there are 2 cams.....etc...
        1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
          <blockquote>quote:</font><hr>Originally posted by F1GT:
          Correction:
          <hr></blockquote>
          uh oh, you better tell those guys running mustang gt's their cars can't run!! they only have 2v/cyl!!!
          [img]tongue.gif[/img]
          anyway, yeah, refer to the howstuff works link.
          2011 Camaro LS 6M, in black.
            The cams don't necessarily have anything to do with the number of valves. OHV is _usually_ 2 valves/cylinder, SOHC is usually 2, and DOHC is usually 4.
            But not always.
              <blockquote>quote:</font><hr>Originally posted by navyblue2000:
              <hr></blockquote>
              oh yeah, forgot about Cheapo Ford....
              Honda Accord 3.0 SOHC 24 Valve V-6,.,.,.,.,and most other manufacturers has at least 4 valves/cylinder for OHC engines.
              [ April 09, 2003: Message edited by: F1GT ]</p>
                I've never heard of a 4 valve SOHC engine before, how do they do this? I saw where Ferd is making all of it's modular (4.6/5.4) engines into SOHC with 3 valves per cylinder so that they could breath better but wouldn't have the added cost of a DOHC to do 4 valves.
                David
                1995 Nissan Hardbody King cab XE, 5-speed, 4 banger<p>Looking for the right Camaro...
                  Never heard of a 4Valve/cyl SOHC???
                  Here are some more:
                  Acura TL Type S 3.2L SOHC 24 Valve V-6
                  Chrysler 300M/Intrepid 3.5L SOHC 24 Valve V-6
                  Dodge Neon 2.0L SOHC 16 Valve I-4
                  These have 3/cyl:
                  Benz S500 5.0L SOHC 24 Valve V-8
                  Chrysler Crossfire 3.2L SOHC 18 Valve V-6
                    Sounds like OHC and DOHC are better than OHV. Are there any advantages we have with our OHV engines?
                    Also, is there a big difference between a OHC and a DOHC engine.
                      it is true that sohc have either 4 or 2 valves/cyl.
                      Ive seen the setup on ripped apart honda motors and it is actually a very simple setup. I cant really explain it without drawing a picture. there has been a lot of people saying that ohv engines are low tech and ohc are high tech however i dont believe either one is ahead of the other in technology. Ohc and ovehead valve engines have been around for over 40 years, so its not like cutting edge technology. They are both better for different purposes. As far as power goes it is impossible to say either way. They have ohv and ohc engines that produce well over 1k horsepower when modified. One advantage of the dohc engine is the ability to change the valve timing(not all can do it though). Allowing then to run smooth at all rpms.
                      2002 camaro SS 6 speed, black, with black leather: Whisper lid/filter<br /> 98 silver camaro v6 a4(sold)<br />few mods
                        Since were talking about this. I noticed on www.60degreev6.com that there's a guy who is swapping in a FWD 3.4 DOHC v6 into his 3rd gen camaro(obiviously RWD now). :D DOHC 3.4 Camaro
                        nice to see someone doing something different
                        [ April 11, 2003: Message edited by: Shay ]</p>
                          "Sounds like OHC and DOHC are better than OHV. Are there any advantages we have with our OHV engines?"
                          Not much. Maybe manufacturing cost? A little less maintenance (OHC drive belts/chains).
                          "Also, is there a big difference between a OHC [SOHC] and a DOHC engine."
                          Again, not much. The advantage, as you go from OHV (requires pushrods and rocker arms) to SOHC (requires rocker arms or less than ideal valve geometry to eliminate them) to DOHC (cams sit directly on top of valves) is that you take something out of the valve train and have more direct contact from cam to valve. That means the valve operation can be faster and more precise.
                          It's enough of an advantage that no one building a competition engine would ever use something other than DOHC if the rules permit them. On a street car, it's not that big a deal. Mostly DOHC lets you get more power from the same displacement and possibly a bit better fuel economy.
                            The advantage that OHC engines have over traditional engines is a reduced amount moving mass in the valve train. It takes high spring loads to prevent valve float at high Rs and since most engines are getting smaller, it is taking higher RPMs to get any power out of them. By reducing the reciprocating mass, the valve springs can be lightened up and will require less power to over come them during operation and the efficiency will improve. DOHC engines typically don't have a lot of low end because of the large flow area around the valves, reducing the intake velocity.
                            OHC engines are more expensive to produce because of the extra head machining and more cam blanks to turn during munufacturing. That's about all that I know.
                            1995 Firebird 3.8 A4, 140,000 miles and going strong<br />Basically Stock, college=poor <p>Junior Mechanical Engineering Student: Milwaukee School of Engineering; Cpl, MN Army National Guard...just got promoted :)
                              Thanks guys...
                              The future GT is supposed to be a 3 valve per cylinder either OHC or DOHC engine. What would it be...2 intake or 2 exhaust valves?
                              I know more valves means better flow getting air in and out...that much I know. [img]redface.gif[/img]
                                6 days ago
