Just wanted to share my experience with my Valve cover Oil leak - FirebirdV6.com/CamaroV6.com Message Board
  • Just wanted to share my experience with my Valve cover Oil leak
    Well~
    For a while now I've had an oil leak from what I was pretty sure was my valve covers. I really couldn't see where the oil was coming from on the engine, but it was driping right onto the Y-Pipe.
    So, last night I decided to go to town, and try to tighen my valve covers.
    On the Passanger Side, I got to 5 of the 6 very easy. The last is blocked by a lift bracket. Any ideas how to get rid of that brakcet?
    The driver side invovled a bit more work. First I removed the EGR and the tube next to it. I then removed the plate that it was mounted on. With this gone I was able to remove the lift bracket on that corner of the engine. Then I removed the whole block of coil packs. With all of this out of the way, it was easy to tighten all 6 bolts on this cover.
    Well, upon getting home tonight I let the car idle for a while, and low and behold, no smoke coming from the headlights as I had been getting, which was the oil burning off of the Y-Pipe.
    Anyways, so if you have this problem, I sugguest you do this. Its not a real hard job, it takes maybe 2 hours tops. Just make sure you have a gasket for the EGR, or some of the high temp gasket maker, as I used when you replace the EGR.
    If anyone else has done this, how do I remove the lift bracket on the passenger side?
    Thanks!
    1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
