I own a 96 V6 firebird with regular number odometer. I want to upgrade to the 155mph gauge cluster, but the only one I can find looks like it has the digtal read-out. Will this work in my car? That would be cool if I had digital read-out. I can post a picture of it if it helps.... how do you post pictures?
will digital odometer work in my car?
someone on here has an all digital guages. so, i guess it will work\'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
Do a search for this under digital gauges or gauge replacement or such terms as this. I know that somebody has done this, either replaced the whole dash cluster or just added single digital gauges with multiple options that come with this digital gauge. Thier is one gauge that I have seen that has a odometer, speedometer, tachometer, trip odometer,etc. It has been done before. If I remember right part of what was needed was to connect to the VSS (vehicle speed sensor) at least for the gauge I mentioned.I'm not positive if you just want a didgital odometer but if you want an all in one type of gauge then you can connect through the vss and have it still transmit a signal to the PCM while at the same time sending a signal to the digital gauge. Do a search in the various forum rooms, check out the appearance forum also as well as this one because I think that it may have originally been posted there. Let us know what you find out. I'll see if I can find the information. I saved it a while ago on my old hard drive. Email or post me if you have any questions. Take care and good luck. Let us know how it turns out.
[ September 21, 2002: Message edited by: Skullcamaro ]</p>1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...2 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...2 weeks ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...2 weeks ago
by AZ3.8CamaroI have a 15 year boy now (crazy how time flies from when I was a teenager on here!) and his first car will be the old Camaro.
I stopped driving...3 weeks ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...4 weeks ago
